  • 3.65K
  • 202
  • 615
Community elder
Message 21 of 102
Re: 1GB fibre but not getiing 1GB
@MarkPi wrote:
Have you tried a speedtest using http://www.dslreports.com/speedtest (rather than speedtest.net)?
Also worth rebooting your PC just before you try it to make sure nothing else is using some resources.
safe mode with networking would be better probably.
  • 65
Message 22 of 102
ok so here are the results
PC booted as normal, but with AV and stuff disabled
http://www.dslreports.com/speedtest/55866200
PC in safe mode with network
http://www.dslreports.com/speedtest/55865902
So there is something slowing it down it would seem
  • 41
  • 7
Dialled in
Message 23 of 102
Well at least you’ve proved it’s not Virgin.
Time for a new PC....?
  • 65
Message 24 of 102
Its always nice to know your getting what you pay for 😀
A new PC has been on the cards for a long time but I'm trying to hold out as long as possible, and current PC is playing games without issues
  • 14.74K
  • 620
  • 1.42K
Message 25 of 102
Your i7 is fine for 1Gb
Uninstall your AV.
  • 65
Message 26 of 102
I have tried it without AV, taking off any network software installed with lan drivers just incase and still seems to be the same, the fact in safe mode I hit 950+ means it has to be something driver related or software.
Just need to work out which, it has been 3 years I think since last install so its due a clean install
Thank for all the suggestions you have been very helpful
  • 2.91K
  • 51
  • 268
Problem sorter
Message 27 of 102
Have you tried TOTALLY resetting the Network stack?
If this is Win 10 I would wait a short while longer on 1909.
  • 65
Message 28 of 102
Hi jhuk
I had not done a full reset, I have now.
last test I'm getting around 700
Yea will wait for windows update before doing a reinstall if a clean install does help, but not done a test install yet
  • 65
Message 29 of 102
So I remembered I had a bootable flash drive with ubuntu on it, so I ran speed test via that, only the on forgot the name for other site
So going to try a fresh windows install on a test SSD next
  • 65
Message 30 of 102
An update
I it would seem it was a network card driver causing the slow down.  I tried an older driver, gave better speed but more buffering on the connection, on newest dirver was the other was slower speed less buffering.  As my network adaptors are built on, and my motherboard is old the drivers I could get where not that new.
I bought a cheap £10 TP-Link network card, and that is running find with 950 down when I know someone was watching Netflix. So I did not need a reinstall it was just bad drivers for my motherboards network adaptors.
I will run test again when no one else is using internet, but seems better
