BooTooo
  • 30
1GB fiber connection upgrade on Friday 8th of January 2021 and terrible performance since
Hello all,
I am in Area 20 (Kent near Bromley) and upgraded to the Virgin 1Gb Fiber connextion last Friday as I was tired of poor downloading speeds experienced with my 200M connexion since the beginning of the confinement.
I also received in late 2020 a message from Virgin indicating that all network upgrade work had been completed in my area (that was one of the main cause of past poor performance according to Virgin support team)...
Find below the result of this upgrade (between 20 to 40% of packets loss...)
Today is the worst with TEAMS and virtual sessions with my work not working at all (permanent lag and disconnexion...).
Virgin support team please help me understand what is going on as according to your website, your network is working without any trouble.
Thank you in advance as currently, the situation in unbearable...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: 1GB fiber connection upgrade on Friday 8th of January 2021 and terrible performance since
Please do this before posting the Hub Data
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again.
Use one post for each tab if you wish.
Please do not use screen shots.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Possibly a waste of time but what speeds do you get at >> Sam Knows Real Speed << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
BooTooo
  • 30
30402750000-0.838.6QAM25630
11387500000.236.4QAM2561
2146750000036.6QAM2562
3154750000-0.536.6QAM2563
4162750000-1.336.4QAM2564
5170750000-0.336.6QAM2565
6178750000-0.137.4QAM2566
7186750000036.6QAM2567
8194750000-0.236.6QAM2568
9202750000-0.137.4QAM2569
10210750000-0.337.4QAM25610
11218750000-0.237.6QAM25611
12226750000-0.137.4QAM25612
13234750000-0.137.6QAM25613
14242750000-0.337.6QAM25614
15250750000-0.537.4QAM25615
16258750000-0.637.4QAM25616
17266750000-0.437.4QAM25617
182747500000.137.6QAM25618
192827500000.237.4QAM25619
20290750000037.6QAM25620
21298750000-0.437.6QAM25621
22306750000-0.337.6QAM25622
23314750000-0.237.6QAM25623
243227500000.237.6QAM25624
25330750000037.6QAM25625
26370750000-0.637.6QAM25626
27378750000-0.837.6QAM25627
28386750000-0.938.6QAM25628
29394750000-0.938.6QAM25629
31410750000-0.838.6QAM25631
30Locked38.60537700
1Locked36.38689000
2Locked36.60965300
3Locked36.60965300
4Locked36.38689000
5Locked36.60965300
6Locked37.35598800
7Locked36.60965300
8Locked36.60965300
9Locked37.35598800
10Locked37.35598800
11Locked37.63627600
12Locked37.35598800
13Locked37.63627600
14Locked37.63627600
15Locked37.35598800
16Locked37.35598800
17Locked37.35598800
18Locked37.63627600
19Locked37.35598800
20Locked37.63627600
21Locked37.63627600
22Locked37.63627600
23Locked37.63627600
24Locked37.63627600
25Locked37.63627600
26Locked37.63627600
27Locked37.63627600
28Locked38.60537700
29Locked38.60537700
31Locked38.60537700
159864K1680QAM1024424
159Locked410.3744870390
BooTooo
  • 30
The connection spped is now back to normal. It must have been a big networok problem on virgin side but without any public notifications...
Here is a copy of the new test I ran.
