1GB drops when not in safe mode
dan0401
When in safe mode my speeds are 950mbps and when not in safe mode my speeds are 400/500 and very inconsistent.
Any ideas? brand new copy of windows 11 with only the windows defender as an anti virus
5 REPLIES 5
I am all Macs but will spare you from my obvious response 🙂
see if there are any clues in these 3 recent threads...
See message 7 in the first thread and 9 in in the second and 3 in the third
https://community.virginmedia.com/t5/Speed/HUB-5-and-IGB-wifi/td-p/5088163
https://community.virginmedia.com/t5/Networking-and-WiFi/Slow-Ethernet-Speed/m-p/5060946#M484321
https://community.virginmedia.com/t5/Speed/Upgrade-from-M600-to-Gig1-no-speed-change-with-Hub-4/td-p...
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & BT sport), x3 V6 boxes (1 wired, 2 on WiFi) Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
unfortunately nothing from them 3 posts has helped
Short from a reinstall try this
https://www.lifewire.com/reset-network-settings-in-windows-11-5194111
carl_pearce
Trouble shooter
What method are you using for testing?
Have you tried:
https://samknows.com/realspeed/
http://proof.ovh.net/
I may have solved the issue, tcp optimizer and a play around with some settings and I think I have solved it
