on 11-01-2023 16:48
Tried the pin reset, tried calling customer services who ran through the same WiFi tests every time even though I'd shared that the speed tests have already been completed and I'm looking at the ethernet issue.
Was told a ticket can't be raised for a technician to visit because they have to send me a cable first. I've checked all the cables, they all work, and are cat6 etc
I'm getting the 1GB hit the router but none fo the devices are getting anywhere near. Most top out around 90-300mbps.
On a iMac (ethernet Cat6) and checked the hardware settings and MTU settings. All seem correct.
Not quite sure what to do next.
Any help would be much appreciated.
on 11-01-2023 16:54
You test to see where the speed is being lost.
Assuming your Hub is in the regular Router mode the link below attempts 2 tests
+ first a speed test from the internet to the Hub - this should reflect the subscription rate
+ second a speed test from the hub to the device - the results of this are very dependent on
the connection method and are often limited by the capabilities of the device especially where WiFi is involved.
on 11-01-2023 17:10
Yep, done both of those many times over the last few days.
Current numbers are...
Router gets 1149
Device (ethernet) 189
on 11-01-2023 19:09
on 12-01-2023 16:26
Thanks for the detailed response. Much appreciated.
After testing speeds across MBP and iMac and iPads/iPhones etc with cabled vs wifi I think I found the problem.
Even though the spec of the ethernet cables are rated cat6 1GB, it seems one of the cables is throttling at 100mbps.
This was proven by switching the router ethernet out from the switch box for a direct link to each machine. All speeds dropped instantly.
Now getting the expected speeds.
Can anyone suggest a good brand of ethernet cable for 1GB please? need to run from downstairs to an upstairs room (approx 25M).
Cheers for all the help so far.
on 12-01-2023 16:44
12-01-2023 16:44 - edited 12-01-2023 16:47
I have had good success with Amazon Basics Cat 6 cables for short patching. For long runs I make my own cables. Try and avoid "CCA" cables, as these are Copper Coated Aluminium. Look for a solid copper cored ones, and not the flat cables either.
I've also used Kenable and Rhinocables in the past. Anything over Cat 6a will be a waste of money btw.
on 12-01-2023 17:48
Great stuff, thanks.
That will definitely help avoid buying the wrong cable.
on 12-01-2023 17:49
All brilliant advice and appreciate you sharing the money saving tip.
I'm on it! Fingers crossed.
