1GB Upgrade - Not Much Speed Upgrade
anaschillin
Below is the configuration in my Hub 5 which i received today and plugged in. Set into modem mode. Ran couple of speed tests
5 REPLIES 5
Hi @anaschillin
You should post your downstream logs again, this time as text, the screen shot unreadable
To be honest all hub readinsg should be posted as text. The  network logs have been rejected as they contain your MAC address. Again they should posted as text - the forum system will remove the MAC address if posted as text.
Dave
The do's and don'ts.
Posted as Text
1499000000-138QAM 25612
24830000000.938QAM 25610
3491000000-138QAM 25611
45070000000.938QAM 25613
5515000000-138QAM 25614
6523000000-1.138QAM 25615
7531000000-1.138QAM 25616
8539000000-1.138QAM 25617
95470000000.938QAM 25618
10555000000-138QAM 25619
11563000000-1.338QAM 25620
12571000000-1.638QAM 25621
13579000000-1.638QAM 25622
14587000000-1.438QAM 25623
15595000000-1.438QAM 25624
16603000000-1.538QAM 25625
17611000000-1.338QAM 25626
18619000000-1.138QAM 25627
19627000000-1.338QAM 25628
20635000000-1.338QAM 25629
21643000000-138QAM 25630
226510000000.638QAM 25631
236590000000.538QAM 25632
246670000000.638QAM 25633
256750000000.238QAM 25634
26683000000039QAM 25635
276910000000.338QAM 25636
286990000000.738QAM 25637
297070000000.638QAM 25638
307150000000.339QAM 25639
317230000000.439QAM 25640
1Locked381440
2Locked381070
3Locked381280
4Locked381410
5Locked381610
6Locked381990
7Locked382580
8Locked383130
9Locked382650
10Locked383140
11Locked384340
12Locked385130
13Locked386210
14Locked385760
15Locked384850
16Locked385090
17Locked386620
18Locked387510
19Locked388000
20Locked387980
21Locked388120
22Locked388600
23Locked388970
24Locked387280
25Locked386750
26Locked396630
27Locked385970
28Locked386310
29Locked385140
30Locked395240
31Locked396380
01-12-2022 11:20:50noticeUS profile assignment change. US Chan ID: 10; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 11:15:47noticeUS profile assignment change. US Chan ID: 10; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 11:02:56errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:49:50criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:49:35criticalDHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:49:34criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:49:26criticalDHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:49:25criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:49:22criticalDHCP FAILED - Critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:44:02criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:42:15noticeREGISTRATION COMPLETE - Waiting for Operational status
01-12-2022 10:42:11warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:42:11warningDynamic Range Window violation
01-12-2022 10:42:10noticeUS profile assignment change. US Chan ID: 10; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:42:05noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:42:02criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:42:01noticeTLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:41:59warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:41:56noticeHonoring MDD; IP provisioning mode = IPv4
01-12-2022 10:41:52criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:41:52criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:41:48criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:41:47criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:41:41criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
01-12-2022 10:41:28criticalCable Modem Reboot due to master console reset
01-12-2022 10:41:27criticalCable Modem Reboot due to master console reset
01-12-2022 10:24:12criticalCable Modem Reboot from SNMP
16-04-2022 09:47:04criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Hi anaschillin,
Thanks for coming back to us on this one.
We're sorry to hear you're having an issue with your connection. Checking things this end, the hub is looking great. All power and signal levels are within range and there are no open faults in your area.
I can see you have Modem mode on so am assuming you're using a third party router. Please disconnect this and instead plug the ethernet cable in to the Hub and PC/Laptop directly. Reboot the hub and check the speed then.
Are you seeing any difference? You'll need to ensure the ethernet is a cat 6 minimum and that your PC/Laptop is also capable of running 1GB speed.
Pop back and let us know how you get on.
Kath_F
Check the hubs Max Traffic Rate in Operation Configuration
test modem mode without a router connect PC to hub power off hub for 2mins then back on unplug replug Ethernet to get internet then test speed.
anaschillin
Right it turns out, its Asus Router. AI protection features limits speeds. - So best to turn that off. Still tweaking the settings for optimum speeds. Manged to get about 800Mbps peaking to 850 to 900 Mbps
