mattwellsy
  • 87
Message 1 of 5
1GB Service, but not 1GB speed
Hello
Just been checking my speed and it seems I'm not getting 1GB, What should I check to make sure things are ok my end?
jb66
  • 12.96K
  • 987
  • 1.94K
Message 2 of 5
Re: 1GB Service, but not 1GB speed
You could try using the official speed test for 1Gig customers
mattwellsy
  • 87
Message 3 of 5
Hello
That test requires hub to be in router mode, ni e is in modem mode with a edge router controlling my lan setup.
So cannot run as far as I can tell
Richw1982
  • 503
  • 34
  • 121
Rising star
Message 4 of 5
That would be the first step.  Pinhole reset, disconnect all ethernets and try https://www.samknows.com/realspeed/ as above.
I work for VMO2 but all opinions are my own and are based on my own experiences
Zoie_P
  • 4.86K
  • 203
  • 376
Message 5 of 5
Hi Mattwellsy,
Thank you for your post.
I have checked your power levels and your stats all looks fine. Have you run the test as advised by @jb66? And followed @Richw1982 advice on how to do this?
Zoie
