  • 100
1GB Broadband Upgrade Boost
Because i live in the Bolton area. I have been told that i can get 1GB😎 broadband in my area.  Today I am awaiting for the engineers to arrive at my address.
To install the brand new modem router "SH4".  I will configure the "SH4" later on.  (for all my devices).
Currently this morning I was on 500MB😎 DL and 37MB UP. Max
Bolton Area Speed Test
  • 3.48K
  • 564
  • 1.36K
Re: 1GB Broadband Upgrade Boost
You don't think you're tempting fate here?  😀
  • 100
1GB Broadband Now Completed
Results
  • 2.86K
  • 51
  • 261
Problem sorter
I am just curious is you knew before you got it that you will never get 1Gb/s from the LAN port on the HUB4?
The Tier/Config will be be 1.1Gb/s with the added 10% Contention so that is 200-300Mb/s missing.
Can you run the internal Samknows App and see if you get 1Gbs/+
  • 100
The App on a S8 Galaxy only gets 1/2 the download speed.
See Results
  • 2.86K
  • 51
  • 261
Problem sorter
I mean the software built into the HUB4 that will do a speedtest
https://samknows.com/
https://samknows.com/blog/virgin-media-launches-samknows-realspeed
