samiko_uk
Message 1 of 5
1G + Hub 4 nightmare!
Hi all
I have upgraded to 1G recently and received my Hub 4 yesterday. Since then I have been experiencing slow and intermittent connection and lots of drop out, the Hub 4 seems to be rebooting constantly! I have reset the device and still the same issue, also I am no where near my 1 G speed, getting less than I was getting when I had my 500M line.
See below for router stats....
Please help!
3.0 Downstream channels
253310000006.80000337.355988QAM25625
113900000010.59999838.983261QAM2561
214700000010.19999738.983261QAM2562
31550000009.40000238.983261QAM2563
41630000009.40000238.605377QAM2564
51710000009.09999838.983261QAM2565
61790000008.90000238.605377QAM2566
71870000009.09999838.983261QAM2567
81950000008.59999838.983261QAM2568
92030000008.80000338.605377QAM2569
102110000008.69999738.605377QAM25610
112190000008.19999738.605377QAM25611
122270000008.19999738.605377QAM25612
132350000007.69999738.605377QAM25613
142430000007.30000338.983261QAM25614
152510000007.40000238.605377QAM25615
162590000007.30000338.983261QAM25616
172670000007.40000238.605377QAM25617
182750000007.80000338.983261QAM25618
192830000007.59999838.983261QAM25619
202910000007.80000338.983261QAM25620
212990000007.30000338.605377QAM25621
223070000006.90000238.605377QAM25622
233150000006.90000238.983261QAM25623
243230000006.69999737.636276QAM25624
263390000007.00000037.636276QAM25626
273470000007.00000037.636276QAM25627
283550000006.80000338.605377QAM25628
293630000006.19999737.636276QAM25629
303710000006.09999838.605377QAM25630
313790000006.09999838.605377QAM25631
25Locked000
1Locked563869800
2Locked555405400
3Locked554635300
4Locked518829500
5Locked550857300
6Locked560540500
7Locked560204800
8Locked61060100
9Locked58431170
10Locked63517100
11Locked59676500
12Locked62103900
13Locked58898700
14Locked57935800
15Locked58903800
16Locked55859900
17Locked60587600
18Locked58623100
19Locked54786000
20Locked53566900
21Locked57537200
22Locked55771100
23Locked55593400
24Locked93431500
26Locked94212800
27Locked93515100
28Locked94263400
29Locked90115300
30Locked94450000
31Locked5208288800
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked 3.11755521403
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 5
Re: 1G + Hub 4 nightmare!
@samiko_uk wrote:
Hi all
Please help!
You have two Downstream Power Levels that are too high and the differential between the lowest at +3.1dBmV and the highest at 10.6dBmV is too great.
These will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
samiko_uk
Message 3 of 5
Thanks Mike
I will wait for someone from Virgin Media to get in touch with me, I have already tried twice to call but couldn't get through!
Sam
samiko_uk
Message 4 of 5
Update! This is really getting worse and worse .. the router is having it's own mind restarting so often! we seem to have this issue when there is activity on the line, and very stable off peak!
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f96b485318acc33586de1a6c35f1d4d13f...
HELP PLEASE!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 5 of 5
It will be 08:00 in 45 minutes, get on the phone to them.
