  • 7
Message 1 of 12
150mb on 350mb package wired ethernet connection direct to router
I have been getting this issue for ages now. I still believe there is a fault with something. Speedtests show half of the speed that I should be getting. I never used to get this issue. Technical support tried everything from restarting, new router, cat6 cable, checking my hardware ect. Nothing has fixed the issue.
My hardware is connected PC gigabit ethernet direct to router.
323000000
Locked
Ranged Upstream Channel (Hz)
53700000
Locked
Provisioning State
Online
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
21/10/2019 20:49:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2019 14:52:1ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2019 09:28:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2019 12:42:54ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2019 19:59:55ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2019 15:56:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2019 03:47:14ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2019 01:32:55ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2019 02:48:17criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2019 08:59:0ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2019 13:11:38ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/11/2019 23:46:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2019 06:36:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2019 06:36:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2019 06:36:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2019 06:36:29Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2019 06:36:49Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2019 06:36:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2019 06:41:44criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
SFID21444
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID21443
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
1537000004.575512016 qam5
2326000004.5512016 qam3
3394000004.55512016 qam2
4258000684.45512016 qam4
  • 7
Message 2 of 12
Re: 150mb on 350mb package wired ethernet connection direct to router
1323000000-138256 qam24
21390000000.238256 qam1
3147000000038256 qam2
4155000000-0.238256 qam3
5163000000-0.238256 qam4
6171000000038256 qam5
7179000000-0.238256 qam6
8187000000-0.238256 qam7
9195000000-0.438256 qam8
10203000000-0.538256 qam9
11211000000-0.738256 qam10
12219000000-0.538256 qam11
13227000000-0.738256 qam12
14235000000-0.938256 qam13
15243000000-0.938256 qam14
16251000000-0.738256 qam15
17259000000-0.938256 qam16
18267000000-0.938256 qam17
19275000000-138256 qam18
20283000000-0.738256 qam19
21291000000-138256 qam20
22299000000-0.538256 qam21
23307000000-0.938256 qam22
24315000000-0.738256 qam23
1Locked38.6220
2Locked38.6380
3Locked38.61840
4Locked38.94007
5Locked38.9890
6Locked38.6500
7Locked38.6190
8Locked38.6180
9Locked38.9110
10Locked38.6230
11Locked38.6100
12Locked38.990
13Locked38.6350
14Locked38.61360
15Locked38.9220
16Locked38.980
17Locked38.660
18Locked38.680
19Locked38.940
20Locked38.680
21Locked38.6110
22Locked38.630
23Locked38.660
24Locked38.660
3ATDMA0000
4ATDMA0000
  • 1.29K
  • 183
  • 613
Message 3 of 12
Your upstream channels have all dropped to 16 QAM - now that might be normal for your area if the kit hasn't been upgraded but if you say it used to be OK plus the errors in the logs would indicate that you have an upstream noise (interference) ingress issue. Check all the cable connections are tight but I suspect you'll need an engineer visit to check everything.
  • 3.48K
  • 564
  • 1.36K
Message 4 of 12
Power levels good, SNR good, errors levels OK, but your upstream is dropping back to 16 QAM, and that suggests a line quality problem, even though your speed test shows a full speed upstream performance.  Wait for the forum staff to take a look, and see what they can do, but I suspect you may need a technician visit.  In the meanwhile check that the connections from the hub to the wall box are full secure.
Due to the exceptionally complex nature of DOCSIS, an upstream indicated problem can affect downstream measured performance, and vice versa.
  • 7
Message 5 of 12
Thanks for reply both.
I have checked the cable from the router to the connection box and that cable is a push in connection and it is a tight fit and secure.
  • 5.98K
  • 305
  • 533
Message 6 of 12
Hi vm2817, thanks for posting and welcome to the community. I am sorry about the lower than expected speeds.
I've ran a check on the area and your connection and no issues are showing. However, I can see the router has not been rebooted or reset for 20 days. Can you try this for me, and then do a wired speedtest on a non-console device, at speedtest.net with only that device connected to the internet?
Kind regards,
John_GS
  • 7
Message 7 of 12
  • 7
Message 8 of 12
Just checked all the cables to the wall and all tight to the connectors. The cable setup has not changed since I moved in.
  • 3.77K
  • 171
  • 297
Message 9 of 12
Good Morning vm2817,
Thanks for your post on our Community Forums and a very warm welcome to you!
Are you able to try and resend the images you attempted to send at 7:10pm last night as these failed to come to through to us on the forum?
I suspect this was of a wired speed test after the router was rebooted or reset.
Kindest regards,
David
  • 7
Message 10 of 12
I'm not sure why you cannot see it. It is this image: https://i.imgur.com/U8zyJ08.jpg
