acehud
  • 8
Message 1 of 13
100mbps connection down to 30-40mbps sometimes even 10
For the last couple of weeks my internet has been quite bad. I've had consistently low speeds for my connection and sudden packet loss and high latency spikes. I've tried multiple fixes online with no success. I'm using wired connection for my main machine, and have restarted/reset my router with little success for consisent improvement. I'm also experiencing this through multiple devices and OS's so it's not my computers/phones problem either.
Any help would be hugely appreciated.
Please see below tech details of my logs:
MY BMQ
Anonymous
Not applicable
Message 2 of 13
Re: 100mbps connection down to 30-40mbps sometimes even 10
post the logs and stats from the hub
acehud
  • 8
Message 3 of 13
Downstream:
1331000000-1.237256 qam25
2235000000-3.732256 qam13
3243000000-3.232256 qam14
4251000000-331256 qam15
5259000000-3.231256 qam16
6267000000-333256 qam17
7275000000-3.236256 qam18
8283000000-2.434256 qam19
9291000000-1.928256 qam20
10299000000-1.433256 qam21
11307000000-1.536256 qam22
12315000000-1.736256 qam23
13323000000-236256 qam24
14339000000-136256 qam26
15347000000-0.936256 qam27
16355000000-1.733256 qam28
17363000000-2.433256 qam29
18371000000-2.435256 qam30
19379000000-2.236256 qam31
20387000000-236256 qam32
21395000000-235256 qam33
22403000000-2.736256 qam34
23411000000-3.236256 qam35
24419000000-3.435256 qam36
1Locked37.3252284295189
2Locked32.62101863823275507
3Locked32.2-491310831147141868
4Locked31.9165248452440289160
5Locked31.199709253-1219861892
6Locked33.8101600278323985
7Locked36.371211042811
8Locked34.42875173183945
9Locked28.2-1886981327-1448375612
10Locked33-66142598217842489
11Locked36.685280008371
12Locked36.6161978039152
13Locked36.6537073823123
14Locked36.3155459967322
15Locked36.62422363278
16Locked33.9452546848933
17Locked33.311733128991046
18Locked35.76999352106
19Locked36.32247024453
20Locked36.374576569
21Locked35.74667371
22Locked36.65138625
23Locked36.3202786
24Locked35.7202587012
Upstream:
1537000005.1512064 qam2
2394000005.1512064 qam4
3462000005.1512064 qam3
4603000005.1512064 qam1
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 4 of 13
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
acehud
  • 8
Message 5 of 13
3ATDMA0000
4ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cxv9873254k;fg87dsfd;kfoA
SFID27586
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID12430
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
Anonymous
Not applicable
Message 6 of 13
you have low SNR on some channels. you'll need an engineer to look at that
acehud
  • 8
Message 7 of 13
04/11/2020 19:49:29Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:49:29Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:49:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:49:17Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:49:3Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:49:3Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:48:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:48:46Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:48:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:48:33Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:48:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:48:16Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:47:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:47:25Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:54Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:41Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 19:46:14Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
acehud
  • 8
Message 8 of 13
@MikeRobbo :126.58 Mbps for my main device
@apcyberax: Would virgin be able to organise it from this thread or would I need to phone them considering we're about to enter lockdown again?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 9 of 13
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
acehud
  • 8
Message 10 of 13
r to this Re: 100mbps connection down to 30-40mbps sometimes even 10
Is anyone from VM going to answer to this thread?? My internet got super bad last week, where it was cutting off constantly and I called the support team who confirmed straight away that I'll need an engineer, which was booked. Then couple of days later I got a text that VM are doing a fix on the street, and cancel the engineer visit, which went on, my internet got better for couple of days and it is now acting up again with high latency/slow speeds and cut offs...
I'm working from home & using the internet for recreational uses so I absolutely cannot continue going on with this shabby connection as I can't properly do zoom calls or do online gaming anymore...
BMQ from today as an example
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/0a661afc571ec60fb7a1d91bcdb3ad52275b0a6c">My Broadband Ping</a>
