Tapatrick
100mb speed now only 24mb
Just checked my internet speed. Usually it is in the 90's now only 20-25mb. I am working from home and use wired connection to router and need the speed for my work.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: 100mb speed now only 24mb
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Then
Can you please
Tapatrick
Thanks MikeRobbo for the great info. Today the speeds are back up to 110mb+... but I will store your post for later reference.
Tags (1)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Set up the BQM anyway, it doesn't interfere with anything and is useful to have at hand.
Padmecat
I'm having the same issue - it happens really often, 100mb speed ramps down to about 24mbs.
Just set up the BQM as per the instructions from the first helpful answer - now what?
here is the link
https://www.thinkbroadband.com/broadband/monitoring/quality/share/ad17cd7aeb12b2f1ddf6d332000df346c2...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
@Padmecat wrote:
... snip ...
If you want assistance please start your own thread.
