Mattbec68
100 speed
Only getting 32 down load and normally hit around the 70 mark, for ever buffering lately try contact this crap company and no luck always take the money though any ideas
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: 100 speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Anonymous
Not applicable
Re: 100 speed
Why wouldn't they take your money considering it's a direct debit?!
Tags (1)
