  • 8
10% of advertised speed
Hello,
I've had consistently bad speeds (around 10% of advertised speed) and intermittent connections to the world wide web for about three months now, if not longer.
Phoning up is pointless - after 15 minutes of waiting I get cut off
Can someone help? Otherwise I'm ending my contract.
£45 for level of service is unacceptable.
Thanx for reading,
Sam
  • 4.81K
  • 880
  • 1.28K
Re: 10% of advertised speed
Hello
Can you please post your network stats from the hub
Open a Web browser (e.g. Internet Explorer) and enter the address http://192.168.0.1
Note: If you have enabled Modem Mode on your Hub 3.0 you will need to use 192.168.100.1 instead.
Do not login but click on where it says "Check Router Stats" and then copy and post from the following 4 tabs, Downstream, Upstream, Configuration and Network logs and we can check your power level, also while you about that can you please go around and check that all connectors to VM equipment are hand tight. Also while doing this please check for any damage to cable, or un-terminated connections wihout either coax or a terminator.
Regards Mike
  • 6.1K
  • 310
  • 540
Hi SamC,
Thanks for posting and sorry for the broadband issues.
Can you check the tightness of all the cables please?
If these are fine, then it will be an engineer visit needed as per our checks. Let me know and I can help further.
Kind regards,
John_GS
