cfaice
  • 13
Message 1 of 5
10% Speed - RCS Partial Service
Evening,
My broadband has been a bit slow over the past week; now I've investigated, I'm hitting 30Mbps down and 35Mbps up on the 350Mbps package.
Hub is in modem mode, utilising a Ubiquiti UDM Pro as the router and main switch which I am directly connected while performing tests.  Modem output below; supplied a small sample of the logs as they repeat between the RCSP Partial Service and Lost MDD.  Had attempted to phone Virgin, but a message stated they are closed and try visit the not so helpful faults page.
I have rebooted everything and checked connections are secure.  What's the verdict?!
14/10/2020 20:36:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 20:36:18Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/10/2020 20:34:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1299000000138256 qam21
21390000000.738256 qam1
31470000001.238256 qam2
41550000001.438256 qam3
51630000001.438256 qam4
61710000001.938256 qam5
71790000001.738256 qam6
81870000001.738256 qam7
91950000001.538256 qam8
102030000001.238256 qam9
112110000001.237256 qam10
12219000000138256 qam11
13227000000138256 qam12
142350000000.538256 qam13
15243000000038256 qam14
16251000000038256 qam15
172590000000.538256 qam16
182670000000.738256 qam17
192750000000.738256 qam18
202830000000.438256 qam19
21291000000138256 qam20
22307000000138256 qam22
233150000001.238256 qam23
243230000001.538256 qam24
1Locked38.93886611245
2Locked38.24970983232391
3Locked38.611653582054552
4Locked38.66723452928729
5Locked38.64454783186405
6Locked38.96146031230829
7Locked38.65886002387386
8Locked38.910075081641207
9Locked38.9740650130098
10Locked38.950677154210
11Locked37.347012977704
12Locked38.6463851132092
13Locked38.9654527199808
14Locked38.9707340264184
15Locked38.6541375346203
16Locked38.9456647333745
17Locked38.6538583319962
18Locked38.9742311233995
19Locked38.6477971190649
20Locked38.9425007114784
21Locked38.930968339009
22Locked38.9508010
23Locked38.6139740
24Locked38.6169156
1537000004.975512064 qam2
2603000005.025512064 qam1
3462000004.875512064 qam3
4394000004.875512064 qam4
3ATDMA0000
4ATDMA0000
jb66
  • 12.27K
  • 911
  • 1.78K
Message 2 of 5
Re: 10% Speed - RCS Partial Service
Signals look good you really need to test directly from hub
Anonymous
Not applicable
Message 3 of 5
You do have a large number of errors on the majority of your downstream channels:
22Locked38.9508010
23Locked38.6139740
24Locked38.6169156
When was the last time you rebooted the HUB?
cfaice
  • 13
Message 4 of 5
Rebooted 3 hours prior to capturing the above logs.
Putting 2 and 2 together;  teams of virgin engineers had  been visiting a duct outside my house last week, believe they connected up a neighbour and saw them installing and pulling in some cable; I wonder if something has been nudged out of place.
Anonymous
Not applicable
Message 5 of 5
Or they moved you to another connection...
