1 month in and not getting full speed
keithsb
I recently upgraded from 500mb to 1gb, I have recently purchased Netgear Orbi and the speed from the virgin router wired is not getting the full speed, even wiring up to my laptop never goes past 800mb.
I used to get full 500mb speed when on the 500mb package, so why am I not getting the full 1gb.
I called VM 2 weeks ago and they done tests and stated nothing wrong with it, the lady even said well it’s fast….if I pay for something though, should I not get what I pay for.
not sure if can tell anything from the pictures
5 REPLIES 5
Most you get is 940Mb.
Anonymous
Not applicable
The lady even said "well, it's fast". I suppose it exceeds the contractual minimum speed and as mentioned above until the hub 5 is rolled out you will be restricted to 940 mbs.
Usual advice with third party routers is to disable QoS and universal beamforming.
@Anonymous wrote:
<snip>   until the hub 5 is rolled out you will be restricted to 940 mbs.
Even with the Hub 5 all Gigabit ethernet will still top out at about 940mb.   You will need to upgrade to 2.5Gb or 10Gb ethernet to get the full 1GB speeds.
Paulina_Z
Hi @keithsb,
Welcome back to our Community Forums! Thank you for your post and I'm very sorry to hear that you're having some issues with your speeds! I understand that this might be quite frustrating.
You can take a look at our Minimum Expected Speeds on our website to see what minimum speeds you should be getting.
Can you please try rebooting your Hub? This can sometimes push through some updates and help with speeds. I can see that your uptime is currently showing as over 64 days, so a reboot would be good for the system.
You can also take a look at our Speed Up page to see if this can help with the speeds.
Keep us updated on how you get on and if you need any further assistance.
Thank you.
Paulina_Z
ozsat
Superstar
You are best using this site - https://samknows.com/realspeed/ - to check your VM speed.
That will tell you what you router gets and that is what you pay for.
You will not got more than 940Mbs on any single device - and a lot of devices will struggle with that.
Some browsers have issues too.
1.2Gb/100Mb in Oxford (area 31) using SH5
