on 28-12-2022 18:13
Just upgraded to 1 gig from M500 and have just had a Hub5 installed
I was getting 450mbps wireless with the M500 and I’m getting no increase in speed at all in fact often less
speed to the hub is 1150ish why am I getting no improvement in speed ?
Definitely not worth the upgrade
28-12-2022 18:25 - edited 28-12-2022 18:26
Most likely the device is maxing out on Wireless - try an Ethernet cable.
Are you using 5GHz?
