1.1Ghz speed?
I was looking around on my Router Settings (192.168.0.1) and I saw that my internet can go up to a speed of 1.1Ghz, on the 5Ghz network. Is it possible to do this? I checked the box for the speed and then I ran a speedtest through my computer (wired over ethernet), but it still stays around 100-110mb speed. How do I boost this?
My router is a Virgin Media Super Hub 2ac.
  • 4.65K
  • 853
  • 1.23K
Re: 1.1Ghz speed?
Hello
The speed you get on the wireless will be also dependent on your broadband speed so if you are on a 100mb service that is all that will show on the speedtest.
Regards Mike
  • 20.96K
  • 1.13K
  • 2.7K
Re: 1.1Ghz speed?
“1.1Ghz” isn’t a speed.
Your internet will go as fast as you’re paying for.
Re: 1.1Ghz speed?
Ah I see.
Thank you!
