testingmichael
0.08MB upload Speed
My download speed usually maintains around the 100MB however my upload speed goes to 20 then down to 0.08, making talking to other people online painful as my mic usually cuts out [ bad for online school & gaming ]
Thanks, [ proof ]
https://gyazo.com/4bfb97ad357eb75df87c037a67cead04
- Mikey
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Re: 0.08MB upload Speed
What speeds do you get at >>  SamKnows << with a direct connection using a Cat 5E or better ethernet cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Then immediately after …
Can you Login to the Hub Settings and navigate to the Connected Devices page - what is the reported 'connection speed’ for the ethernet cable connected device you used for the speed test ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Can you please
Hub 4 When the page appears LOG IN then Advanced Settings > Tools > Network Status.
