kiebal
Settling in
Message 1 of 5
Open Door Street Cabinet
The Virgin Cabinet at the top of Old Hale Way in Hitchin SG5. #LH06000 is wide open and easy to vandalise. Tried and failed to shut it. Incredibly difficult to even report this! Can someone come and shut it please?
Graham_A
  • 16.16K
  • 2.26K
  • 6.9K
Message 2 of 5
Re: Open Door Street Cabinet
You  should report it here:
 https://community.virginmedia.com/t5/Digital-life/How-to-report-damage-to-street-equipment/ba-p/4151...
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
kiebal
Settling in
Message 3 of 5
Thanks - am trying but that's not very clear either!
kiebal
Settling in
Message 4 of 5
I can't believe how difficult this is to report. First you can't leave a phone message, then you can't simply email. Then I tried that link you gave me and it says not available.
Graham_A
  • 16.16K
  • 2.26K
  • 6.9K
Message 5 of 5
Not sure why you are getting not available.
I have just tried the link and it works.  Press on post a comment to add your report.
Graham
