baobaoshan
problem on plug into wall socket
I am trying to plug into the socket on wall. However there is a cable on the existing hub that the Virgin cable cannot fit in. What should I do? Thank you !l
Tom_W1
  • 3.66K
  • 198
  • 342
Re: problem on plug into wall socket
Hi @baobaoshan thanks for your post although I'm sorry to hear you're having issues with your set-up.
I've ran some checks for you and all your services appear to be working correctly - did you get the help you needed to sort this?
Please let us know if you need any further assistance and I'll do my best to assist you.
Many thanks
Tom_W
baobaoshan
Thanks for your reply. I have sorted this out. Thank you!
