  • 23
Message 1 of 5
help
hi can somebody help please ive got a v3 router which ive had for nearly a year with no problems untill now problem being ive got a f/stick downstairs with no problems on wifi but my tablet which i use in the same room keeps buffering done a speed test via my tablet with ookla which vergin reccomends and all im getting is 5mb d/load speed done a test via laptop and its saying 49mb which is near enough what im paying for and my f/stick upstairs buffers also so can anybody advise please? i dont know if theyve sent an update to the router which has messsed the wifi signal up many thanks
  • 4.81K
  • 880
  • 1.28K
Message 2 of 5
Re: help
Hello
Have a look at the wireless troubleshooting :- https://community.virginmedia.com/t5/Digital-life/WiFi-Wins/ba-p/3958523
You can also install the Virginmedia Connect App and do a scan in particular for black spots and depending on your plan you may be entitled to free boosters.
Regards Mike
  • 14.9K
  • 1.17K
  • 3.48K
Message 3 of 5
Re: help
check the wifi bands are split and smart wifi is turned off - there have been no updates to the hub and even if there were it should not affect your setting - however if you have reset the hub or its reset itself for any reason that would put all settings back to default which could explain your problems allowing all has been ok previously
____________________
Tony
  • 23
Message 4 of 5
Re: help
hi mate how do i check wifi bands are split and smart wifi is turned off?many thanks
  • 15.7K
  • 1.64K
  • 2.68K
Message 5 of 5
Re: help
Go into the Hub3 settings. Type in http://192.168.0.1 into your web browser’s url box) and login with settings password on the Hub's base sticker (or your own if you changed it). Then in Advanced>wireless disable "smart wifi" – click apply changes.
Then, go to advanced>wireless>security, rename the 2.4 & 5 GHz network ssid's. Just change 'em to whatever you like and something that will differentiate them (e.g - xxxxx2 & xxxxx5) -- use the same password if you like, also disable “connect automatically” on the 2.4GHz band after the bands have been separated. Then, apply settings and restart the Hub.
