ventura83
  • 34
Message 1 of 8
connector cable for hub 5
upgraded my hub today and realised i never had a connector cable for the coax and was wondering would i be able to request one here?
BenMcr
  • 22.81K
  • 2.51K
  • 4.84K
Message 2 of 8
Re: connector cable for hub 5
The Hub 5 should go on the same coax connection as your previous Hub, you shouldn't need a different cable.
ventura83
  • 34
Message 3 of 8
i was requesting a connector cable for more stability
  • 6.09K
  • 512
  • 1.57K
Message 4 of 8
What connector cable?  It's all the same co-ax cable as the other Hubs?  Are you referring to the isolator cable from the Quickstart kit?
ventura83
  • 34
Message 5 of 8
any VM mods around? this link references a fly lead?  but this is what is missing from my hub:  https://community.virginmedia.com/t5/Virgin-Media-TiVo-service/V6-Box-Cable-Adaptor-IEC-or-Fly-Lead/...
BenMcr
  • 22.81K
  • 2.51K
  • 4.84K
Message 6 of 8
That's for Virgin TV V6 and 360 only as those boxes have a different cable connection to Hubs and older TV boxes.
All Hubs have the same coax connection type. No new coax cable is required if you're swapping an existing Hub for a new one.
ventura83
  • 34
Message 7 of 8
thanks, i thought i was missing something to stabilize the cable due to occasionally getting a low signal strength due to the router being knocked.
John_GS
  • 14.41K
  • 737
  • 1.34K
Message 8 of 8
Hi ventura83
Thanks for posting and thanks also to the community for confirming about the cabling. Sorry to hear about any signal issues. Nothing is showing from a system check that I've done here, all levels are in spec and no outages.
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a Broadband Quality Monitor. This will monitor the state of your connection and record any network dropouts etc
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum 🙂
Best,
John_GS
