on 30-05-2023 08:24
Hi, i have a bit of a problem my coax where it connects to the Hub 3.0 has snapped internaly due to the hub being moved around on the work surface so much.
I have removed the cable from the hub and stripped the cable back and connected a cheap twist f type connector to get the internet temporarily back on before the kids attack due to not getting their minecraft & fortnite fix.🙄
It seems to be working but would like to get this sorted properly. What would be the best thing to do?
Answered! Go to Answer
on 30-05-2023 11:41
Hi @jonnyg
You should call 150 from a Virgin landline or mobile, or 0345 454 1111, option 2 (Faults)
When calling Faults you will hear the automated response asking you to press 1 for the link to online support etc
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone and book the tech for you.
Or wait a day or two and a member of the Forum Team should pick this up for you and arrange a tech visit.
on 30-05-2023 11:41
Hi @jonnyg
on 30-05-2023 12:12
Thanks Newapollo, hopefully one of the tech team will pick this up..... My experience of ringing Virgin in the past hasn't been the best 😆
01-06-2023 12:25 - edited 01-06-2023 12:26
Hello jonnyg.
Thanks for or letting us know about the snapped connection.
Great work on the temporary fix.
So we can put a stop to the possibility of a 3rd wold (minecraft/fortnite) war.
Its half term and we know kids need a fix.
Would you like me to arrange a Technicians visit to replace the cable?
If you can check your envelope at the top right of your screen that would be great.
Gareth_L
on 01-06-2023 16:20
Hi jonnyg,
I'm glad I've managed to arrange help for the Hubs connection.
You can view this appointment via your online account here. If you need this changed, you can do this up to 24 hours before the appointment. Someone over the age of 18 will need to be in the property when the engineer is present.
Let us know how you get on with this, we're always happy to help if needed.
Gareth_L
01-06-2023 16:35 - edited 01-06-2023 16:56
Edit: ignore me Gareth, its just come through via text. Thankyou 👍
Hi Gareth I've logged into my Virgin account but I can't seem to find the appointment details.
on 04-06-2023 10:28
