  • 14.58K
  • 1.14K
  • 3.4K
Message 11 of 59
Re: another hub router,Will work or not
you are to some degree putting the cart before the horse - if your input is wrong then adding a new router will not add anything
describe your problem and post some levels
log into hub3 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labeled - upstream - downstream
is your problem poor speed - or poor wifi or what
____________________
Tony
  • 41
Message 12 of 59
if i got internet everything works fine.. no problems really..
only problem is that internet keep droping last few weeks every day..
yesterday no internet from 6pm till 7am..
in a day time happens few times..sometimes restarting router works..most of times not..even hard reset with pin hole doesnt help..
as i read many posts hub 3 is faulty..i tried to rang vm but its same story all the time..cut the power off ..what colour of light i can see bla bla bla..
day after technician coming broadband working well..no issues found..
day after internet is gone again..etc..
so, what i think..just want to use hub as modem and connect with good router hoping it works..
  • 14.58K
  • 1.14K
  • 3.4K
Message 13 of 59
if the connection is dropping why do you think running hub3 in modem mode will change anything - it will still drop if the problem is the connection so post the levels as asked
reading on here proves nothing - those that post have problems - they may sound the same but the cause may not be - the hub3 works - yes its poor for gamers but it does not have a problem as you imply
not of the few million users who do not have problems post how great it is - thats the nature of a place like this
Tony
  • 41
Message 14 of 59
im trying to paste it but doesnt allow me..
  • 41
Message 15 of 59
Correct the highlighted errors and try again.
  • 14.58K
  • 1.14K
  • 3.4K
Message 16 of 59
it should auto correct so just click the post button a second time
Tony
  • 41
Message 17 of 59
2019-01-17 17:06:07.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:06:07.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:06:14.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:06:15.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:17:58.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:18:00.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:28:22.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:28:23.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:36.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:36.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:37.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:38.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:39.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:39.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:40.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:29:40.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:30:26.00 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:30:26.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:30:34.00 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2019-01-17 17:30:35.00 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 41
Message 18 of 59
1 39400000 48.3 5120 64 qam 22
2 25800000 47.3 5120 64 qam 24
3 32600000 47.8 5120 64 qam 23
4 46200000 48.3 5120 64 qam 21
1 ATDMA 0 0 2 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 1 0
4 ATDMA 0 0 1 0
1 299000000 -3.7 40 256 qam 21
2 323000000 -4.2 38 256 qam 24
3 315000000 -4 38 256 qam 23
4 307000000 -3.7 38 256 qam 22
5 291000000 -3.5 40 256 qam 20
6 283000000 -3.5 38 256 qam 19
7 275000000 -3.2 40 256 qam 18
8 267000000 -3 40 256 qam 17
9 259000000 -3 40 256 qam 16
10 251000000 -3 40 256 qam 15
11 243000000 -3 40 256 qam 14
12 235000000 -2.7 40 256 qam 13
13 227000000 -2.5 40 256 qam 12
14 219000000 -2.5 40 256 qam 11
15 211000000 -2.5 39 256 qam 10
16 203000000 -2.2 40 256 qam 9
17 195000000 -2 40 256 qam 8
18 187000000 -1.7 40 256 qam 7
19 179000000 -1.5 40 256 qam 6
20 171000000 -1.5 40 256 qam 5
21 163000000 -1.4 40 256 qam 4
22 155000000 -1.5 40 256 qam 3
23 147000000 -1.5 40 256 qam 2
24 139000000 -1.2 40 256 qam 1
1 Locked 38.9 86906 45767
2 Locked 38.9 81120 52737
3 Locked 38.9 84590 53537
4 Locked 38.9 86346 50945
5 Locked 38.9 89476 46774
6 Locked 38.6 98802 47922
7 Locked 40.3 104282 50470
8 Locked 40.3 115886 53996
9 Locked 40.3 124229 53990
10 Locked 40.3 135155 54566
11 Locked 38.9 153095 57244
12 Locked 38.9 179809 61465
13 Locked 39.3 217243 67979
14 Locked 38.9 288457 78020
15 Locked 38.9 344791 85377
16 Locked 38.6 358989 88377
17 Locked 40.3 359395 86850
18 Locked 40.3 359694 84315
19 Locked 40.3 384302 84698
20 Locked 40.3 452513 95873
21 Locked 40.3 504336 122384
22 Locked 40.3 523375 172305
23 Locked 39.8 533344 178852
24 Locked 38.9 546928 167181
  • 14.58K
  • 1.14K
  • 3.4K
Message 19 of 59
levels are ok - pre and pst rs errors on the downstream are awful - they may be historical - roboot the hub - leave it off a couple of minutes and that will zero the pre and post rs levels then post them again in 24 hours or less if they have numbers like you have now
Tony
  • 41
Message 20 of 59
ok thanks for now. we will be in touch
