  • 41
Message 1 of 59
another hub router,Will work or not
Hi guys quick question. my hub 3 is piece of....
I want to switch it of and reapleace with hub 2ac.
I want to get 1 from ebay because last time technician took it when repleaced with hub 3.
 Will it work like plug and play ?
or it needs to be dedicated somewhow to mine virgin account?...
  • 17.05K
  • 1.8K
  • 4K
Message 2 of 59
Re: another hub router,Will work or not
No equipment from eBay will work.
If you don’t like the Hub 3.0 as a router, your only choice is Modem Mode with your own router.
  • 41
Message 3 of 59
this hub 2ac its from ebay but VM one..
someone upgraded and got old one left..i had no issues with my old one..but it was taken by technician and i was given new one 'better'...
..and i just want to back to hun 2ac
  • 17.05K
  • 1.8K
  • 4K
Message 4 of 59
... and as I said - you’ve wasted your money and the eBay seller likely knew that. Ask for your money back.
  • 41
Message 5 of 59
i havent bought it yet..
what im trying to find out is.
if i swap my hub 3 with your hub 3 for example. is it gonna work plug and play and i couuld use any hub 3 without any authentication etc? ?...
And what kind of router i need if want to buy new? I know its not adl not dsl so what type exacly?
  • 14.69K
  • 1.52K
  • 2.5K
Message 6 of 59
You cant swap Hubs about - each one is rented to your account and is "locked" to that account. VM are very reluctant to even re-activate the SH2/ac that were left behind after Hub3 upgrades - very few have been successful.
You need a gigabit cable router - lots of recommendations on here - depends on your budget and what extra features you want
  • 15.13K
  • 1.66K
  • 3.45K
Message 7 of 59
What part of "it won't work" don't you understand.
Virgin is a closed system. Unless you are issued the kit directly by Virgin & hence it is linked via your account to their systems, all you are buying is an expensive door stop.
VM's systems know which optical node each piece of kit is connected too. If the kit is moved elsewhere it gets disabled automatically.
VIP pack with VIVID 350. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
  • 17.05K
  • 1.8K
  • 4K
Message 8 of 59
I’m not sure why you would want to swap one Hub 3.0 for another Hub 3.0 but it wouldn’t work anyway.
All Virgin Media equipment must be supplied by Virgin Media and correctly registered on your Virgin Media Account.
Given my Hub 3.0 works perfectly, supplying my contracted speed, even by WiFi, I have no information to give you on the best  router, should you wish to use your Hub 3.0 in Modem Mode.
I’m sure there are other on the forum who can advise you.
  • 41
Message 9 of 59
I need to max 100£..
my broadband is 100mb dont need much extra..
stable conection and dual band..thats it..any recomendation pls?
  • 14.69K
  • 1.52K
  • 2.5K
Message 10 of 59
Not directly as I use all Apple gear. But £60-100 will get you a very good and capble cable router. The Asus/Netgear/TP-Link ranges gets lots of support on these forums. Look/search in the Networking &WiFi forum - there are loads of posts from satisfied customers with pointers and instructions on how to set up.  Get one with a high AC - >AC1200  Here are some of the best - albeit pricier ones...
https://www.techadvisor.co.uk/test-centre/pc-peripheral/best-wifi-router-3217482/
