Wireless Virgin Box
Can I use a virgin box without the white cable coming into the room? I have internet signal in the room both via WIFI and ethernet cable.
If not what are my other options? as the room is very difficult to get the virgin cable into
  • 6.02K
  • 1.14K
  • 1.6K
Re: Wireless Virgin Box
Hello
All VM equipment needs a connection to the VM coaxial cable to be able to get the signal. There are no other options.
Regards Mike
