Ohowejen
  • 13
Message 1 of 9
What Ethernet cable do I need for V6?
I received a replacement V6 box yesterday, but it didn’t come with an Ethernet cable and I don’t have my old one.
What size cable (eg what CAT??) do I need to connect V6 to the internet box?
It wouldn’t let me connect via WiFi when I tried last night and I’m so fed up with going round in circles on the Virgin FAQs that I’ll just buy my own Ethernet cable!
Thanks.
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.02K
Message 2 of 9
Re: What Ethernet cable do I need for V6?
Hello
The minimum requirement for the V6 box is Cat 5e. Strange that it doesn't connect to wireless, when you go and try to connect wirelessly does it show the wireless network, do you get any error messages.
Regards Mike
Christy_D
  • 1.44K
  • 204
  • 231
Message 3 of 9
Good Morning,
Either a CAT5 or CAT6 ethernet should suffice.
Is the V6 box right next to your Superhub? If possible we always recommend hardwiring the V6 anyway as it will vastly improve the speed of our on demand services.
Christy
Ohowejen
  • 13
Message 4 of 9
Thanks.
It comes up with a screen saying “now connect your tv box to the hub” but I can’t move the selection down to “connect to WiFi” - the arrows on the remote don’t affect it! (Even though the remote works).
So I seem to be stuck on that page until I can connect via cable!
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 9
Do the arrow keys work on the programme list ?
Christy_D
  • 1.44K
  • 204
  • 231
Message 6 of 9
Try holding down the 'info' button on the V6 remote for around 10 seconds. See if that helps at all as it should re-pair the V6 remote with V6 box.
Also you can try pressing the channel down button that may help you get onto the connect to wifi option.
If it still doesn't let you, you can always try a simple reboot of the V6 box.
If there is an ethernet plugged into the V6 box though it will not let you connect to wifi.
Christy
Ohowejen
  • 13
Message 7 of 9
I can’t get to programme list until I’m connected! 😬 They used to work until last week...
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 8 of 9
Do the arrow keys work on any part[s] of the menu ?
  • 23.9K
  • 2.53K
  • 4.34K
Message 9 of 9
Christy
Any Cat5 cable is likely to be limited to 100Mbps but more importantly, also >15 years old.  I would only use one in a sticking plaster situation.  Cat5e has been the 1GB standard cable for many years.  Cat6/7 are normally specced with increased shielding from crosstalk and electrical interference and so I would always recommend one of those as there is minimal price difference.
