  • 79
Was sent a Hub 3 (not a Hub 4) - How to return it?
No idea what customer service is doing but they promised to send me a Hub 4 to see if it would help address numberous issues I've had.
It arrived today. It is (of course) a Hub 3. I already have a Hub 3.
I don't have the time to call back in about this. What should I do?
  • 3.52K
  • 567
  • 1.38K
Re: Was sent a Hub 3 (not a Hub 4) - How to return it?
What should you do?  Plug the replacement Hub 3 in and see if it improves things.  If your problems were down to a faulty hub, chances are the replacement will solve things.  Realistically it probably won't because the vast majority of connection problems are down to variants on noise or power levels (and a generous smattering of over-utilisation issues).
A Hub 4 would be no better, and may even be worse because it is more reliant than the Hub 3 upon having very good connection quality.
If I'm right and the replacement hub makes no difference you might want to try these forums to help get a better idea of what is at the root of your problem, and the options for getting it fixed without dealing with VM's dismal offshore support.
  • 79
Thanks but the Hub 3 was just replaced 2 weekends ago so I don't want to go to the bother of replacing it and setting it up all over again. Hub 4 was sent out by them to see if it would be a more reliable longer term solution.
Not sure what to do with the Hub 3 I've received as I don't need it. I called them to check and latest is they won't send a Hub 4 here as not yet a Gigabit area. So don't know why at the weekend they said they would.
Not sure how to return it. Just stick the return sticker on it I guess that was meant for the current Hub 3 and send the new one back?
  • 2.18K
  • 89
  • 136
HI pdampier
please see the following link for packaging
https://www.virginmedia.com/help/virgin-media-return-or-recycle-equipment
Chris
