on 12-01-2023 21:04
Hi today I received my QuickStart package however when I went to install the hub I noticed my virgin media wall socket on the inside was blocked off with some kind of hard paste or cement, this makes it impossible to screw the hub you can’t get to the threads I have already booked a engineer but was just curious why this would happen? I then found another socket upstairs looked a little fresher but that also had same problem with thread bit it was blocked.
12-01-2023 21:53 - edited 12-01-2023 21:58
@Jvee wrote:Hi today I received my QuickStart package however when I went to install the hub I noticed my virgin media wall socket on the inside was blocked off with some kind of hard paste or cement, this makes it impossible to screw the hub you can’t get to the threads I have already booked a engineer but was just curious why this would happen? I then found another socket upstairs looked a little fresher but that also had same problem with thread bit it was blocked.
Probably irrelevant if you have a tech booked but, if you feel like it and for interest's sake, can you post a photo of the problem?
Often poor building work, or poor decorating, can see old VM connections and wall boxes covered over in splodges of paint or plaster.
on 15-01-2023 10:39
Hi @Jvee 👋,
A warm welcome to our Community Forums and thanks for your post. Great to have you on board with us.
Sorry to hear of the problem with your wall socket. I've taken a look at our systems and can see a manned install was subsequently arranged and you're all set now 😊
If we can help with anything else, don't hesitate to reach out.
Don't forget to download the MY VM app if you've not already - it makes managing your accounts on the go so easy!
