SB76
Settling in
Message 1 of 5
Wall sockets and no connection
Hi all
Just had the Hub 3 delivered for Quickstart.  I've got 2 wall sockets that I think are likely.  1st is unbranded on the outside with a likely looking socket inside but no joy on connecting.  Went outside and there appears to be nothing on the other side (maybe removed).
I've also got an old NTL phone socket so had a look outside at that and I think there is still a connection there.  There is also a lead doing upstairs that looks like it is still hooked up, but the inside of that would connect directly to the lead.
Any ideas?
Photos a bit of a mess but top left is maybe the red herring/nothing outside connection.  Top right is what I think is the actual connection on the outside, bottom is what I think is still connected but won't join the supplied cable.
The non connecting oneThe non connecting oneThe outside boxThe outside boxconnected to outside box but won't join the connectorconnected to outside box but won't join the connector
  • 6.82K
  • 593
  • 1.79K
Message 2 of 5
Re: Wall sockets and no connection
You need an adaptor to use the bottom cable. Available from B&Q .
https://www.diy.com/departments/slx-f-type-satellite-cable-coupler/5028422001905_BQ.prd
SB76
Settling in
Message 3 of 5
Ta, will give that a go
  • 13.9K
  • 1.08K
  • 2.82K
Message 4 of 5
Quicker way. Unscrew cable from white box in top left picture, screw onto cable in bottom picture. Push hub cable provide on other connector on white box.
Kath_F
  • 34.75K
  • 1.34K
  • 2.81K
Message 5 of 5
Hi SB76,
We're sorry to hear you've been having issues with trying to connect up your hub via Quickstart.
Hopefully the advice from the other users has helped but if not and you need further assistance, let us know and we can organise an engineer visit to get things up and running.
Keep us posted.
Kath_F
