Just joined
Wall socket power
I got quick start kit today but without a wall socket power cable (though requested one whilst placing an order for internet).
No chance to speak to anyone from call center - 2 hrs on hold now. Internet isn't working. Any ideas how can I contact them to get that power cable please?
  • 65
  • 13
  • 27
Re: Wall socket power
Good afternoon,
Which power cable is it that you need exactly? Is it the power supply for the hub itself?
If so, I can potentially get an engineer to drop one in to you if they're in your local area.
Steve
  • 275
  • 36
  • 63
Hi there,
When you are referring to wall sockets, can I ask if you are referring to the Isolator Housings where the feed enters the property?
They look like this: https://www.virginmedia.com/help/setup/broadband/wall-socket
If not and you require some additional assistance with the set up of your equipment I've provided a link which may prove useful tomorrow: https://www.virginmedia.com/help/virgin-media-getting-started-with-broadband
If non of this helps, you may need to contact the team for further assistance, please can I advise using the following text message number to raise a query: 07533051809.
I hope this helps
Just joined
Hi, no thought I need additional power cable for the wall socket itself. My patience paid off and finally got through to call center. Lady on the phone said I don't need power cable for socket anymore just for hub which I got. Just working on it 🙂
  • 65
  • 13
  • 27
Glad you managed to get this sorted. 🙂
Steve
Just joined
Yes and no. Apparently there is an issue within a socket itself, or anywhere. Engineer could be appointed end of April so had to terminate agreement as I need good connection for my kids' home lessons.Thank you anyway 🙂
