on 28-08-2023 11:36
Hi there,
I moved into a new flat and got a self start-up kit. Essentially, I can’t figure out how to connect my broadband cable into the wall socket. There are two empty wall sockets but the cable doesn’t fit into either. There is this aerial splitter which seems the most obvious place to connect to, but the broadband won’t set up properly, as there is some hardware connection issue.
Am I missing something obvious? Kinda need the WiFi asap and technician visit would be too late
on 28-08-2023 12:10
That's the correct connector.
What colour does the LED appear as after a few minutes (HUB)?
on 28-08-2023 13:50
Call the pre-installs team and explain your issue, on 0800 052 1734 8AM- 9PM Monday - Friday or 8AM-6PM Saturday and Sunday
It could be the cable is disconnected externally to your property.
on 28-08-2023 14:03
Bearing in mind this is the first setup.
It initially goes solid white, then flashes white, then a solid green WiFi symbol and a flashing green light.
I understand this means there is some connection issue. But, surely, the wire can’t be faulty, it’s fresh from the box.
on 28-08-2023 14:05
Thanks, I’ve rang a virgin and they are sending a technician out, which might be the only solution. But I’ll give this number a call too. From my understanding there was tennant here only months before me successfully using a similar Virgin set up, but you may be correct
on 30-08-2023 14:54
Hi @Olvr98,
Welcome to our Community Forums! Thank you for your first post and I'm sorry to see that you're having some issues with your self-install!
It does sound like a technician appointment will be the best option to have your services connected and have your connection up and running.
Please keep us update on how you get on and if you need any further help or assistance. We're here to help.
Thank you.
