samosa
  • 234
Superfast
Message 1 of 5
Wall connector too low
Hello, I got self install kit when moving into our property and when installing the cable to the inlet the cable came apart from the connector as it took ages to get it in and likely loosened it due to it being bent.
350e32f7-f918-4f57-b19a-6b5ca1217fae.jfif
As i'm unable to do tuck it away with the cable with being so low, anyone walking in this area tends to step on the cable and pull it off the connector. Would VM consider coming out to raise this box a little higher?
  • 13.87K
  • 1.07K
  • 2.81K
Message 2 of 5
Re: Wall connector too low
VM could. move the entry point, but as it is a non fault call out there would be a fee of £25.
  • 6.79K
  • 591
  • 1.78K
Message 3 of 5
You could also remove the wall socket and turn it upside down.  This has been done by some users.
samosa
  • 234
Superfast
Message 4 of 5
Yeah this was what i was afraid of but inlet has previously been installed too close to skirting board which is whats causing the fault.
Tom_W1
  • 3.66K
  • 199
  • 343
Message 5 of 5
Hi @samosa, thanks for your post although I'm sorry your cable is causing some difficulties within your household.
As @Tudor has mentioned, we'd be able to relocate this for you or move it up slightly but generally, it does cost £25 for a technician (non-fault) call out charge.
However, I would be happy to look into waiving this for you as a goodwill gesture so I'm going to pop you a PM to discuss this in more detail in a private message - please expect this PM to arrive shortly and respond when you can!
Many thanks
Tom_W
