Varney999
Wall Socket: Will My Bell Cablemedia Box Work?
So I've just moved into a new property which had Virgin Media previously. There is a cable connection box (wall socket) already in the house, so my question is can I use Quick Start? It seems the cabling is in place, but the box is not Virgin!
My wall box says "Bell Cablemedia" but I know the previous owner did have virgin fibre broadband previously. I tried calling Virgin but the estimated wait time was an hour.
HELP!! Thanks
-tony-
  • 17.7K
  • 1.37K
  • 4.28K
Re: Wall Socket: Will My Bell Cablemedia Box Work?
if the previous owner had VM then no reason why it should not work - well there are a few but you will not know until you connect the hub
VM cannot test the wiring until the hub is connected so if someone has damaged or cut a cable then that would only show up on connecting the hub
but you have an internal box if its got a screw connector coming out of it thats the 1st thing - trace the wiring back to the external box if thats there and the external box looks ok then order a quick start
____________________
Tony
Paul_262
  • 32
Hi there
i have sent you a private message to get some more details
regards
Paul
-tony-
  • 17.7K
  • 1.37K
  • 4.28K
@Paul_262 wrote:
Hi there
regards
Paul
hmmmmmmmmmmm - why go to pm at this stage - just answer the question - ok you can look up the address - what is that going to say other than VM has installed there before - we know that the OP said so
Tony
