on 05-08-2023 09:34
We have been let down by BT trying to install VOIP system for our NHS clinic, unfortunately my manager didn't realise the people flogging the package are BT affiliates and it's just been let down after let down. Max speed we get on VDSL is approx 62 meg. I realise with Virgin the biggest factors are the quality of the cable from the cabinet to your home and the density of the number of connections inside the cabinet. Unfortunately the area outer London borough close to a large airport very very high population density lots of illegal HMOs etc does not give me much confidence. The cabinet is about 20m away from our premises and if you were to venture to the back of the parade of shops it's a total mess cables everywhere. I've seen the cabinet open a couple of times rammed full of cables with multiple splitters. What do I do? The NHS have stopped supplying N3 lines so data is encrypted and sent via a VPN. They advise to contact your preferred broadband supplier. Looking for a reliable connection and low latency so data can be seen quickly. What do I do?
Answered! Go to Answer
on 06-08-2023 10:49
on 05-08-2023 11:07
What exactly are you looking for ?
1) Where to source a new VOIP service / platform ?
2) Or an answer to can VOIP be run over a VM Internet connection ? ( It can we have 3 VOIP numbers )
on 05-08-2023 11:13
Is Virgin business reliable given my findings above? We are looking at migrating away from copper based line aka POTS to VoIP. Reliability is crucial as we will be delivering NHS services.
on 05-08-2023 11:33
This is not the VM Business Forum, it's for Residential customers, so the number of Business users here will be very small. Delivering a crucial VoIP solution will, I would have thought, will need at least two ISP supplies for redundancy, not to mention UPS solutions as well. Personally I wouldn't rely on a single point of failure.
05-08-2023 11:34 - edited 05-08-2023 11:40
VM Business does have an SLA for restoring the service I'm sure you have seen that.
Where the internet is business critical it is well worth considering VM Business Internet + BT FTTC / VDSL so you have a back up that is ready to use or even on automatic failover.
on 06-08-2023 10:16
is there a VM business forum, I cant seem to find one!
on 06-08-2023 10:49
I am not aware of a VM Business forum.
