MARIEFRANCESCOT
Just joined
Message 1 of 5
Virgin Media Hub 3.0 constant red light
For over a week now my hub light is red.  I have internet and no issues that I am aware of.  I have done the reboot, reset (with the pin), checked that all the connections were tight multiple times.  I've called the Helpdesk and they have just told me that they have no idea what is wrong but to live with it and ignore the red light until my connection goes wrong.  Not sure if that is great advice and and it certainly is not great service.  Does anyone else have the same issue or has had the same issue and did anyone resolve it, with or without Virgin Media's help?  I am not happy to live with a constant red light, I need my hub to function as it should.
-tony-
  • 19.21K
  • 1.46K
  • 3.76K
Message 2 of 5
Re: Virgin Media Hub 3.0 constant red light
ahh the depth of knowledge of offshore is truly amazing - or put another way they know sod all
likely just the cheap led that is giving up the ghost - the full diagnostics from VM is do a reboot and it should sort itself out - it never does but what do the forum team know thats what they are told to ask which is marginally better than offshore but not much
so wait here and someone should sort it
on the remote chance it is over heating turn it off at night and when you are out until its changed
____________________
Tony.
Sacked VIP
Zoie_P
  • 5.28K
  • 218
  • 409
Message 3 of 5
Hi MARIEFRANCESCOT,
Thank you for your post and welcome to our forums 🙌.
I am so sorry to hear you have been having issues with your hub, I have taken a look and can see you have rebooted recently, if you still have the red light we will need to get a tech out for you.
I will pop you over a PM, so I can get some details. Keep an eye out for the little envelope 📩
Zoie
-tony-
  • 19.21K
  • 1.46K
  • 3.76K
Message 4 of 5
@Zoie_P wrote:
Hi MARIEFRANCESCOT,
Zoie
from the first post
  I am not happy to live with a constant red light, I need my hub to function as it should. - i think that says its still red
Tony.
Sacked VIP
Zoie_P
  • 5.28K
  • 218
  • 409
Message 5 of 5
Thank you for messaging with me @MARIEFRANCESCOT
I am glad I could get this booked for you 😃.
If you want to cancel or rearrange your appointment you can do so 👉 here.
Keep us posted on how you get on and I hope this is resolved for you.
As this is a fault you should not be charged, please ensure someone over the age of 18 is home when the tech arrives.
Zoie
