on 06-05-2023 10:00
Yes when it comes to Online Gaming, ping in ms low latency.
Download speeds don't matter nowadays with all the streaming going on, upload speeds do matter if your on social media a lot or a youtuber uploading a lot of content to YouTube for example. So all that matters nowadays is whether your a gamer or a studio content creator.
Full Fibre aka FTTP or FTTH is better than Docsis 3.0 in terms of online gaming? What about Docsis 3.1 or even Docsis version 4.0?
Can any Docsis version run on any coaxial cable or does the newer docsis 3.1 or 4.0 require new cable laid to the home directly?
Full Fibre lays new cable to the home underground or above ground from the telephone pole?
Do Virgin Media offer and use the BT's Openreach Full Fibre Network or do they stick to their own coaxial cable network that they started laying back in the 90s? Coaxial isn't fibre optic passing the red laser light?
Cheers,
on 06-05-2023 10:30
on 07-05-2023 02:46
have virgin full fttp setup at mine currently, just still waiting on install.
on 11-06-2023 10:10
I have noticed that ping times are slower for those using DOCSIS. Currently I get anywhere from 13ms to 20ms, WiFI will be higher. When you look at speedtests for people that have full FTTP their ping's are about 2ms. I am guessing this is to do with DOCSIS modulation and demodulation over Virgin's fibre backbone, and this takes slightly longer to do?
on 11-06-2023 10:13
Is there any way to sign up to a trial for Virgin FTTP? I have an strange situation where my road has just had Fibre installed by community fibre, and they have a special rate of £25 for 1 Gig or £49 for 3 Gigs! However BT/ SKY et al cant use that, and I would have to wait for openreach to install their version of fibre. Community fibre won't share with open reach. BT will only have fibre on VDSL which gives 65 meg connection!
on 11-06-2023 10:48
That's a no-brainer. Switch to Community Fibre. What are you waiting for?
on 11-06-2023 15:34
It's about the whole package , the TV and landline. The only other serious contender is Sky who are awful. And no I'm not getting a dogibox.
on 11-06-2023 16:27
dogibox?
If you want TV with VM you'll need one of their TV boxes.
on 11-06-2023 20:44
yup that's why I am staying with them as to me they beat sky hands down, and there isn't really an alternative.
on 21-06-2023 10:06
Is the Virgin Media FTTP as unstable as the Docsis cable? Every summer since joining Virgin when it gets hot, the system starts to fall over. It's an ongoing joke in our office of people who are on Virgin having heat connection issues.
