Virgin FTTP power adapter
Jamesdarlison
My power cable to the fibre is broken, there is no green light. Can I source a new one. Engineer is due in 4 days. Second time this had happened now.
3 REPLIES 3
goslow
Not entirely clear what you are describing but ...
If you are referring to the plug-top adapter shown in the images on this topic (which powers the fibre media converter outside)
https://community.virginmedia.com/t5/QuickStart-set-up-and/Internal-Wall-socket-power-supply-missing...
I believe you need a tech visit to replace it. There have been more than a few lengthy pantomime topics in the past trying to get a replacement sent out from VM when, AIUI, the part is not available to send out.
Yes, that's the one and i thought that would be the answer.
It just seems such a waste of an engineer visit just to change a plug.
Is there a design fault with this device? Surely it shouldn't have failed twice, or did it suffer an accident?
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
