stevos9
  • 33
  • 5
Virgin Connect won't block wi-fi
I've recently split my wi-fi signal so both the 2.4 & 5ghz broadcasts.  However can anyone confirm that on split they can still block both signals.  Since splitting it seems I can't block the signal on my sons xbox anymore.
Does the Connect app only block one signal or both - my recent experience suggests that it does not!
Z92
  • 2.01K
  • 166
  • 308
Problem sorter
Re: Virgin Connect won't block wi-fi
It's supposed to block via MAC address (the xbox will have it's own unique MAC address, so it would block all traffic to and from that, for example), but the application is so buggy I wouldn't recommend using it. There are much better ways of WiFi management, most of which unfortunately require extra equipment, but they are worth it in the end.
