catechng
Message 1 of 7
VM wall cable has no hole for installation of hub 3.0
Hi all,
I have received the VM Hub 3.0 but found that the connection cable does not fit into the wall cable.
Please see the images attached. The previous occupier had the same VM Hub and said the cable does fit but with the help of an engineer. It definitely does not go directly into the wall.
I'm not sure how engineer visits work due to COVID but is there any way I can do this myself- can anyone give me a step by step how to? Is there a fee to book an engineer?
Thanks.
WhatsApp Image 2020-09-09 at 18.28.39.jpegWhatsApp Image 2020-09-09 at 18.27.46 (1).jpeg
Tags (2)
jb66
  • 12.17K
  • 900
  • 1.76K
Message 2 of 7
Re: VM wall cable has no hole for installation of hub 3.0
catechng
Message 3 of 7
Thank you for the quick reply!
https://www.amazon.co.uk/Socket-Inline-Connector-10-electrosmart%C2%AE/dp/B0036AWQQC would this be the same? I'm just looking at options on amazon for quicker delivery and set up.
catechng
Message 4 of 7
naboo
  • 43
  • 9
Message 5 of 7
Yes, they are both the same thing, a f connection coupler
what is behind the actual wall plate ?
catechng
Message 6 of 7
That's great, thank you for the help.
jb66
  • 12.17K
  • 900
  • 1.76K
Message 7 of 7
You can get a free visit from Virgin, there is not a need to buy your own unless you want to
