Sdean71
V6 box - do I need a coax to Ethernet adapter
My TiVo box is faulty and is being replaced in the next few days with a v6 box. My TiVo is connected via a coax cable but I’ve read that the v6 box doesn’t have a coax connection. Do I need a coax to Ethernet adapter? Strangely the virgin media staff member I spoke to never mentioned this!
Tags (2)
Johnhelping
  • 12
  • 6
Re: V6 box - do I need a coax to Ethernet adapter
V6 has a coax connection ( it needs a connection to your cable modem via Ethernet or wireless as it has no built in modem unlike the old TiVo boxes)
Sdean71
Thanks - think I’ll have to try and connect via WiFi as router is other end of the room!
  • 23.85K
  • 2.53K
  • 4.33K
Wifi will be fie as long as you have a strong and stable wifi signal at the V6 location. As its in the same room (?) as the Hub it should be fine - if not - come back here for suggestions.
