Jonny-M
  • 46
  • 15
Dialled in
Message 1 of 1
Using Openreach PIA for infill
I've seen that VM are starting to use the Openreach PIA product to get access to ducts in Project Lightning areas, are there any examples of this being used in existing HFC locations for infill? I have a couple of locations in mind, one is a residential road that was left out when NTL were deploying ~20 years ago, and the other is a few units on a business park with surrounding businesses and houses which are all served by VM. In both instances the Openreach services are provided via underground duct rather than direct burial or overhead.
If PIA for small numbers of properties is something that VM do then I'd appreciate a PM so I can give you address details, thanks.
