I have just upgraded to Gig1 from M500 - Was using a SuperHub 3 in modem mode for many years but with this new upgrade came the SuperHub 4. Put it straight into Modem Mode as this fits in with my current home network and has served me well.
I am seeing typically 700Mb Download now and 50Mb Upload. Latency is all over the place and another family member is a gamer and immediately reported the upgrade has introduced lag spikes to gaming. My first hop with tracert is 15ms and a typical speedtest.net is 22ms
Upon looking at the Hub Status I notice power levels are on low from what I have read online and I am noticing the higher frequency channels have lower levels. This would suggest higher losses at higher frequencies. Is this normal?
I have one coax from the cabinet terminated at the front door with a barrel connector and then another cable in the house going to the router via the isolator just before the router. I have no splitters or similar and I only take the Boradband Service. The cable from the cabinet to the house was re-pulled in the last 18 months or so due to degraded signal due to possible ingress.
I will post my router stats below.
Cheers Radio-Pirate
