katyannaking
Upgraded from hub 3.0 to hub 4.0
today i got my 4.0 hub I installed it also got the 1gb internet connection, but my speeds are still exactly the same as when I had my only 350mb connection
I done 11 tests and all test were awful speeds
is there something that I need to do or should it just be plug and play?
Z92
  • 2.01K
  • 166
  • 308
Problem sorter
Re: Upgraded from hub 3.0 to hub 4.0
Is your equipment capable of 1 gbps speeds?
Are you testing using good quality ethernet cables ? or are you using WiFi ?
