Upgrade contract states M250 fibre broadband with VM Hub 4 but I have been sent a Hub 3?
alangigi
I signed up on 23 June for upgrade package to M250 with a Hub 4 but I have been sent a Hub 3. I contacted VM this evening and have been told that a Hub 4 is not compatible with M250? So why do all 3 VM contract documents state Hub 4?
Since upgrading my download speed varies from 250mbps down to 60 mbps. I reboot and it goes back to 250-270. So I am not happy. Previous superhub 2 was rock solid at 130mbps. I want what I am paying for which is a Hub 4.
1 REPLY 1
Hub 3 is more than capable for 250 Tier, as is the Hub 4 btw.
Are you testing wired or wireless as VM only guarantee 20Mb from wifi.
What speed does www.samknows.com/realspeed show?   Your poor performance could be a faulty circuit and a Hub 4 will not fix this.  Post your power levels and network log from the Hub for comment.
