Stagedrivery
Message 1 of 7
Unsightly power socket
We recently had virgin media installed with two tv boxes. We had existing cabling in a new build (to living room) but we wanted the second box to be in the family room where no cables (apart from tv aerial)
installation day they asked to use aerial sockets as a solution and I said yes, but I didn’t realise at this cost.
We now have a quite unsightly setup in the bedroom (pic attached) which is on full show, and I wanted to see everyone’s opinions as I can’t believe this is normal and can’t possibly be put somewhere else. We actually have a utility cupboard with lots of power right behind where virgin enters the property.
anyones thoughts on this?
  • 33.65K
  • 3.3K
  • 6.39K
Message 2 of 7
Re: Unsightly power socket
There is no picture attached.
Ariel sockets as a solution to what?  Both V6's must have a co-ax cable connection to the VM network to receive "cable" TV.
Stagedrivery
Message 3 of 7
Please find picture attached. Didn't work from my phone for some reason.
And our aerial cable is co-axial.
Thanks!
BenMcr
  • 22.81K
  • 2.51K
  • 4.84K
Message 4 of 7
So, as you're in a new build I would say that's the power supply for an FTTP install.
Those installs are converted to coax at the property, and the converter needs power to work.
EDIT: the current New Build handbook does suggest there are non-FTTP HFC install versions of these too. Not quite sure what they do though, but you do get splitters and other distribution kit for HFC that need power.
https://www.virginmedia.com/content/dam/virginmedia/dotcom/images/shop/downloads/New-Build-Handbook-...
Stagedrivery
Message 5 of 7
Hmm yes you are right, just confused why it’s on direct show in the middle of the bedroom and not the utility cupboard like it should be (and like BT is)
it’s not often BT makes sense….
BenMcr
  • 22.81K
  • 2.51K
  • 4.84K
Message 6 of 7
I suppose it depends where they were able to route the cable or fibre at install.
If BT are in a cupboard they that cabling would have been done during the house build.
Virgin Media do recommend the same as you can see in the New Build PDF but that's up to the developer as to what to put where.
Lee_R
  • 6.25K
  • 288
  • 650
Message 7 of 7
Hi Stagedrivery thanks for posting and welcome to our community.
I am sorry to hear you're unhappy with the location of your power socket.  We can look into sending out a technician to relocate this.  There would be a fee of £25.00 to do so.  But you would then be able to discuss the alternatives with the attending technician.
Lee
