jezport
  • 55
  • 7
Dialled in
Think theres a problem in my area
First had poor internet, so rebooted hub4. It tried and went to Red, then came back, went off again worked a bit then rebooted and went red again Area LS17 7LB
Cant get through to virgin. Help!!!!!
  • 26.42K
  • 2.69K
  • 4.89K
Re: Think theres a problem in my area
Have you checked for “known network faults”?
As well as trying the “check service,” Area status webpage" (link at top right of this forum), also try the “free & automated” Service Status number - 0800 561 0061 - which usually tells you of more local issues down to postcode level (that may not be listed on the Area Status web page which usually only covers >1000’s of customers) - that may give you more info, but even that wont cover problems affecting just a few customers.
If nothing shows on there, try calling it in as a fault (on 150 VM line - or 0345 454 1111 others) and see what they say when they test your connection. If they say it’s a known fault, get a fault reference number – n.b.- the UK call centre is still picking up and calling at 08.00 gives the best chance of getting through quickly, although I got through recently in 20' at ~1pm midweek.
