on 19-07-2023 08:19
I have just turned the modem mode on for Hub5 but now the TV has two signs on in red (I had originally paired it with Hub5 using WPS).
What’s the consequence of these two lights and how do I get rid of them? The TV does seem to function fine at the moment.
on 19-07-2023 12:13
It's hard to help when you haven't said that these red signs are. We don't know anything about your TV.
If you have set your Hub to modem mode you will need a separate router, with the TV connected to it instead of the Hub. Have you done that?
on 19-07-2023 18:11
The TV needs to be connected to the Wi-Fi service from your new Wi-Fi Router or Wi-Fi Mesh configuration.
