Anonymous
Not applicable
Message 1 of 10
Superhub 4 Upgrade woes
Hi all,
Noticed Gig1 was available in my area for only £1/mo more than my current M200 package, so decided to upgrade.
Got my Superhub 4 unit last night, replacing my Superhub 3.
Plugged it in, got a text message saying it was activated, but now I'm not getting any internet connectivity. I can connect to the router, the router shows numerous downstream & upstream channels, but I'm not getting any internet connectivity.
I've tried phoning the activation line, and the support line. The second-line support checked that they could restart my router remotely, which worked, so they can access the device.
Anyone else had similar problems upgrading to Superhub 4?
Unfortunately upgrading to Superhub 4 has de-activated my previous Superhub 3, so I can't switch back.
Tags (1)
Anonymous
Not applicable
Message 2 of 10
Re: Superhub 4 Upgrade woes
Status from my router:
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
Anonymous
Not applicable
Message 3 of 10
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
331000000
10.900002
40.366287
QAM256
25
10
211000000
10.300003
38.983261
QAM256
10
11
219000000
10.400002
40.366287
QAM256
11
12
227000000
10.500000
40.366287
QAM256
12
13
235000000
10.500000
40.366287
QAM256
13
14
243000000
10.500000
40.366287
QAM256
14
15
251000000
10.300003
38.983261
QAM256
15
16
259000000
10.400002
38.983261
QAM256
16
17
267000000
10.400002
40.366287
QAM256
17
18
275000000
10.500000
40.366287
QAM256
18
19
283000000
10.000000
40.366287
QAM256
19
20
291000000
9.900002
40.366287
QAM256
20
21
299000000
10.000000
40.366287
QAM256
21
22
307000000
10.400002
40.946209
QAM256
22
23
315000000
10.699997
40.366287
QAM256
23
24
323000000
11.099998
40.366287
QAM256
24
26
339000000
11.000000
40.366287
QAM256
26
27
347000000
10.900002
40.366287
QAM256
27
28
355000000
10.699997
40.366287
QAM256
28
29
363000000
10.699997
40.366287
QAM256
29
30
371000000
10.800003
40.366287
QAM256
30
31
379000000
11.099998
40.366287
QAM256
31
32
387000000
11.199997
40.366287
QAM256
32
33
395000000
11.400002
40.366287
QAM256
33
34
403000000
11.199997
40.366287
QAM256
34
35
411000000
11.000000
40.366287
QAM256
35
36
419000000
10.900002
40.366287
QAM256
36
37
427000000
11.099998
40.366287
QAM256
37
38
435000000
11.300003
40.946209
QAM256
38
39
443000000
11.599998
40.946209
QAM256
39
40
451000000
11.599998
40.366287
QAM256
40
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
0
0
0
10
Locked
895
0
0
11
Locked
3122
0
0
12
Locked
262417944
0
0
13
Locked
895
0
0
14
Locked
895
0
0
15
Locked
3122
0
0
16
Locked
3122
0
0
17
Locked
895
0
0
18
Locked
895
0
0
19
Locked
3122
0
0
20
Locked
263030404
0
0
21
Locked
895
0
0
22
Locked
895
0
0
23
Locked
3122
0
0
24
Locked
895
0
0
26
Locked
895
0
0
27
Locked
3122
0
0
28
Locked
3122
0
0
29
Locked
895
0
0
30
Locked
895
0
0
31
Locked
159971482
0
0
32
Locked
3122
0
0
33
Locked
895
0
0
34
Locked
895
0
0
35
Locked
3122
0
0
36
Locked
3122
0
0
37
Locked
895
0
0
38
Locked
895
0
0
39
Locked
158197554
0
0
40
Locked
8230510
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
41
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
41
Locked
13.2
2126
0
Anonymous
Not applicable
Message 4 of 10
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
53700000
47.770599
5120 KSym/sec
8QAM
2
2
39400000
47.770599
5120 KSym/sec
32QAM
4
3
46200000
47.770599
5120 KSym/sec
32QAM
3
4
25800000
47.770599
5120 KSym/sec
32QAM
6
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
0
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
Anonymous
Not applicable
Message 5 of 10
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
64798
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
64797
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Anonymous
Not applicable
Message 6 of 10
Last few log entries:
Thu 01/01/1970 00:01:173No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 17/12/2020 11:14:125MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 17/12/2020 11:20:413SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 17/12/2020 11:20:465Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 17/12/2020 11:21:056CM-STATUS message sent. Event Type Code: 23; Chan ID: 41; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 17/12/2020 11:24:015MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Anonymous
Not applicable
Message 7 of 10
Hub 4 device information
The information below shows current status of this Superhub 4. I've obfuscated my MAC addresses and IP address.
Strangely the Superhub 4 reports that it has an external IP address, but i can't ping that from other machines I have access to online (via 4G on my phone, or from my work computers). I have obfuscated the last part of my modem MAC addresses and serial numbers)
Standard specification compliant
: DOCSIS 3.1
Hardware version
: 11
Software version
: 01.02.048.09.EURO.PC20(Open Source Information)
Cable MAC address
: E4:57:40:F9:xx:xx
Cable modem serial number
: ABAP0203xxxx
System up time
: 0 days 1h:2m:58s
Network access
: Allowed
WAN IP settings
Your current Hub 4 internet settings are displayed below
MAC address
: E4:57:40:F9:xx:xx
IPv4 address
: 86.18.x.xx
Default gateway
: 86.18.x.xx
IPv4 lease time
: 6 days 8h:5m:52s
IPv4 lease expire
: 23/12/2020 20:30:52
IPv4 DNS servers
: 194.168.4.100,194.168.8.100
Anonymous
Not applicable
Message 8 of 10
I've got this splitter from when I used to have a Virgin Media TV box, but it is capped off with a terminator. I've tried removing it from the equation but it makes no difference.
Anonymous
Not applicable
Message 9 of 10
Strangely my hub reports that it has an external IP address, but i can't ping that from other machines I have access to online (via 4G on my phone, or from my work computers). I have obfuscated the last part of my modem MAC addresses and serial numbers)
The information below shows current status of this Hub 4.
: DOCSIS 3.1
Hardware version
: 11
Software version
Cable MAC address
: E4:57:40:F9:xx:xx
: ABAP0203xxxx
System up time
: 0 days 1h:2m:58s
Network access
: Allowed
WAN IP settings
MAC address
: E4:57:40:F9:xx:xx
IPv4 address
: 86.18.x.xx
Default gateway
: 86.18.x.xx
IPv4 lease time
: 6 days 8h:5m:52s
IPv4 lease expire
IPv4 DNS servers
Anonymous
Not applicable
Message 10 of 10
Gave up in the end. Cancelled my upgrade and reverted back to Superhub 3 with M200 with actually works.
Apparently my cable connection is slightly below par, meaning the Superhub 4 doesn't manage to open a Gig1 connection. Not worth trying to fix this close to Christmas!
