denburydays
  • 19
Message 1 of 34
Superhub 4 Speed Issues
1 Gb Superhub 4 Speed Problems
Intel Wireless-AC 9560 160MHz
Realtek PCIe GbE Family Controller
When using 'samknows.com/realspeed' the 5 results are:
1 392 - 76
2 421 - 78
3 693 - 78
4 429 - 76
5 400 - 79
Have had an engineer visit who states nothing wrong with connection from hub to virgin. It must be the equipment I am using thats at fault. Told him have top end hp i5 notebook etc.
Can someone explain this correct or is their a problem with the Hub of Laptop
  • 33.55K
  • 3.29K
  • 6.37K
Message 2 of 34
Re: Superhub 4 Speed Issues
Run the speedtest this way - should measure it accurately
_________________________
Connect a 1GB enabled computer/laptop, with up to date drivers, via a NEW and working Cat5e/6a ethernet cable, directly to the Hub which you have put into “modem mode” (https://www.virginmedia.com/help/virgin-media-hub-modem-mode ).
This ensures that NO other devices are connected
Test speeds at https://speedtest.samknows.com/ - try on 2 different browsers.
If they are still low – boot you device into windows safe+networking mode - to disable any potentially interfering software - and try again.
There are many posts on here (I have a list of ~30!) where QoS software, unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
denburydays
  • 19
Message 3 of 34
Thanks for the reply and help.  Have done as above (I have even Factory Reset the Superhub 4) - samknow.com/realspeed results show 863 - 92.  ookla shows ping 24  download 447 upload 52
-tony-
  • 18.98K
  • 1.44K
  • 3.65K
Message 4 of 34
log into hub3/4 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
and confirm your speedtests are wired
Tony.
Ex VIP
denburydays
  • 19
Message 5 of 34
I can confirm 'wired' and in 'router mode'.
Have up and down stream info in html and pdf but can't seem to post in reply
-tony-
  • 18.98K
  • 1.44K
  • 3.65K
Message 6 of 34
just cut and paste the levels - if you get an error ignore it and click the post button again
Tony.
Ex VIP
denburydays
  • 19
Message 7 of 34
Have tried a few times to upload html files but stating not allowed over20,000 characters
denburydays
  • 19
Message 8 of 34
Hub 4 - DOWNSTREAM_1.jpgHub 4 - DOWNSTREAM_2.jpgHub 4 - DOWNSTREAM_3.jpgHub 4 - DOWNSTREAM_4.jpgHub 4 - UPSTREAM_1.jpg
-tony-
  • 18.98K
  • 1.44K
  • 3.65K
Message 9 of 34
load the info on the hub on a browser select each page - copy it and paste it here - may need more than one post but it works
Tony.
Ex VIP
denburydays
  • 19
Message 10 of 34
Have managed  by uploading jpg's
